What do you people think of the synthetic blend of pennzoil? That's what the local place around me uses for oil. I was considering doing it myself, but that isn't really an option at this point in time...
Stay away from Pennzoil. It may be the cheapest--it may be the oil most service stations use the most, but it's the worst for your engine. Pennzoil has none of the additives to help keep your engine clean. Mobil1 and Valvoline do. I put Mobil1 Full Synthetic in my car about 1000 miles after I bought it--it ran WORLDS better. I would never allow Pennzoil to touch my baby. I'll look for the "Engine Oil Bible" and post the link when I find it. It shows legitimate studies on oils and oil filters. Basically, use OEM oil filter and Mobil1 oil.
Damn, you only have 93k on your car?? I have the same year as yours and my car gots like 162k miles on it. Back to the subject, I run 5W-30 Mobil 1 Synthetic all year long.
LOL yup 93k and counting, the reason it's that high now is because i moved to a new apt. last oct. and i'm doing about 100 miles a day now from home to work. Back in oct. i only had about 77k on the old GA16DE...
Oil is Oil---As Long as it is lubed it is ok..........Some oils may claim there additives are better but all oils have to pass a certain standard. I personally use Redline because my whole family uses them in there cars and my uncles drag---mustang and it never blew a engine yet. 2 years runnning-----and being pushed to its limits once ever month. But if you follow what is required in your owners manual you have nothing ro worry about
Hi guys,
My 2001 Nissan Caravan (Homy) E24 is not getting any voltage to the glow plugs. The light on the dash is also not coming on at all.
I have checked the plugs, and they are showing 0.7ohm resistance.
I have checked the bulb on the dash and it is working.
The relay is getting 12v from...
I have got my Nissan X-Trail for more than 4 years. I was satisfied with the car radio come with it and used it often for navigating. However, not sure why the screen start to blur and some flashing lines keep on showing up recently.
I have took my car to an autoshop. They helped me to confirm...
I have a 2008 Altima and the service engine soon light come on and the diagnostic tool says code PO420 is showing and its probably the CatConv. Does anyone know if I should change the 02 sensors first, new gas cap, add fuel additive to help clean CC, change the CC, which is the most expensive...
Question? Why won’t my long outer lights on my headlights toward the left not light up? I’ve tried the lights, vehicle settings etc... the regular headlights and highbeams work?
I bought a Nissan march, 1.2l, 2013 and am suprised it doesn't have rpm odometer. You won't know how the acceleration is going on. Any one who has it and why has the company opted to remove it?
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
