Did a pressurized fuel cleaning on injectors. Didn’t help the issue where I drive and come back to the vehicle anywhere from 20 minutes to an hour and half on a hot restart where it stumble for a few seconds.
Sometimes it would even surge at a very low rpm for those few seconds. One time it even died when it did this. After that vehicle is perfectly fine. No drivability issues or problem with cold start and starting after few hours.
I know many have said could possibly be leaky fuel injectors but I want to make sure first before pulling everything apart. Did a fuel pressure test and lost 10 psi in 25 minutes.
that picture data is at idle. When Erving vehicle the short term fuel trims drop down to around 0 or even less sometimes.
Can someone help with the diagnosis
I included some other data.
