i have an sr20det red top and the car started rpming at 2000 when its at idle. hot and cold engine. does someone know how to solve this problem. thanks.
· Admin and Sup Mod keeping the peace
Check the throttle valve for dirt; check the throttle linkage. Use carb cleaner solvent spray.
· LUCKY SLIDES 2 2/25/06
rogoman said:
If there's a bad fuel injector, it'll most like cause the idle speed to decrease and be rough.
also check vacuum lines for leaks and or unhookedness(yes i made that up) generally a vacuum leak will cause an engine to idle higher because its getting more fuel dumped in than air causing a rich condition
