ok i checked and had a code 5 is what i understood from the comp it is a 95 reg cab 4cyl standard shift 4wd it starts up and idles fine while cold if you let it sit there and warm up it will idle down like it should if i drive it a short distance it does ok but if i drive over 10 miles or so it wants to idle at 1500 instead of 700-800 i can go somewere it is actig up and go inside a few minutes when you get back in it acts right untill you drive it again anbody have any idears i was thing maybe the iac anybody else
