im trying to install a sub n amp n whatnot in my girlfriends '94 pathfinder. ive done it before on older cutlas's and older pontiacs n stuff but i cant find a way to get from the battery into the cab for the power. not just that but i cant get into the back of the CD player for the RCAs and the remote wire. could anyone give me a hint on how to do either of these?:confused:
· Moderator
You need help drilling a hole and installing a grommet? ;)
Installing audio in newer vehicles is a little different than doing the same to older vehicles.
If you haven't figured out how to get to the CD player then don't try. You will end up destroying the dash plastic.
Before you break something expensive, take it to a pro audio shop and have them install the amp and subs or at least lay the wires for you.
