1 - 9 of 9 Posts
I got a whole new supension Intrax,KYB, and intrax Cambers, i just added my rims today and the problem is that i tried backing up and i heard my tires rubbing on the rear struts and i couldnt back up normally...do you think it might be the cambers in the rear?? or the could it be the rims?? my car is kind of on a slant on my driveway but just a little, could that be the problem?? think i need spacers to adjust the rims??... let me know cause this shitt is bothering me i dont know if i did something wrong with the cambers??:mad:
First I would look for were it is rubbing and go from there, you should be able to tell by scrape marks from the tire on the inside of the wheel well or marks on the struts. Have you got the car aligned since you did all the suspension work (struts,camberkit,springs,wheels). If not then it could definatly be your camber kit. get it aligned at a place that can handle a lowered car with camber kits. I take mine to NTB, they have that lazer alignment and they have a guy that knows what he is doing with a camber kit. You may have to call around and find a shop that can do it considering your modifications. Hope Iv'e helped.:D
I doubt you actually need a camber kit in the rear of your car, but more than likely your problem is the width of your wheel. Get a small wheel spacer and put it on the rear hubs. This will bring the wheel out away from the strut. I have 18 by 7's on my car for the street and I had to use spacers on the back.
hay AaroNX did ur back tires touch ur struts?? so i should just get spacers...how much farther will it push it out??will it be just enough so it wont touch the strut??
1 - 9 of 9 Posts
