I have a 93 Altima, 150k, that runs smooth, but it has an oil leak. A mechanic said it is leaking oil from the timing chain cover, and maybe somewhere else above the cover--possibly from the head gasket. It is not leaking too bad yet. I only lost 2 quarts of oil in the last 6 months, but I want to keep this car as long as I can.
I do not want to spend the estimated $1200 or so to have this fixed. Is there any way I can do something myself to stop or slow the leak? I have read about the "Right Stuff." Is this something I can apply without taking apart the cover? Or can I add Stop Leak?
I was using full synthetic Mobil 1 10w-30 for 2 years. Now because of the leak I switched today to Mobil regular 5w-30 (it's too cold where I live!). I don't know yet whether this switch will make any difference.
Any help would be much appreciated!
it definetly sounds like it the head gasket.....!! The head gasket, that's an simple fix. Not sure how good you are with tools, But i changed mine in less than 30 minutes and I not a mechanic, far from it. but simple tools and some reading will fi this... good luck...
