1 - 9 of 9 Posts
this car is new to me never heard it run before replaced timing belt but will not start ,the battery was dead when i replaced battery security light flashes does something need to be reset or programed to make the light go out or is this the normal operation . i dont have a owners manual
Locked and Loaded
The security light should only flash when the door is open. Once the door is closed, it will go out until the key is turned in the door. At this point the alarm is armed and the light will remain solid for...like...a min or something. It stays lit for a min or so just so you know it's set...this also gives you a min to grab your keys out of it if you locked them in there. Once the light goes out, the security system is armed and the alarm will go off flashing the lights, honking the horn and engaging the ignition immobilizer until you use the key to unlock the door.
I had to learn all this the hard way...had it going off in a parking lot when I first got my first Z31 and didn't know how to get it to go off...rather funny in hind-sight...
well im adding that i might have found out what the problem is hot sure yet but looks like i was given the wrong belt
1 - 9 of 9 Posts
