Bet people are tired of seeing this. But anyways, about a month ago my heater starts pushing out cold air instead of hot. I check my coolant level, and what do you know, low on coolant. So I put some 50/50 in there and everything seemed to be good. Last week I was driving about 50mph, when the engine bogged down and started to slow down on me. First thing I do is check the dash and wow, my temp is through the roof. So I pull the car over, pop the hood and pull the radiator cap off and add coolant. Drive it back to my house after it cools down, and it hesitates while accelerating, but drives fine at speed and idles fine. I checked the oil when I got home and it was dripping pretty bad. So to be sure I did an oil change, and topped off the coolant. After about 30 minutes of driving around (car still hesitating) it gained a quart of oil, and it looked like coffee with too much cream in it. No white smoke coming from the exhaust.
So now I have this car tore apart, I have the head off and the head gasket looks fine, no obvious signs of a blowout, not even any marks between the jet holes and the rings. I guess basically there are only a few things that will get coolant into the oil, 1: blown head gasket 2: cracked head 3:cracked block 4: bad intake manifold gasket???? The last, I haven't checked yet, I left the bottom part of the intake on the head when I took it off.
So questions: How much does it cost to send a head to a machine shop to check for cracks? Do I need to take the valves out of it? Also the engine has 195,000 miles on it, and since this has pretty much been a problem for at least a month, what is the chance that a spun bearing is inevitable? Also being that I have to replace the control arm bushings and front struts, should I just scrap it and get a different ride?
