This is the result of my test:
- Block (Bore mm) = 76.50mm
- Stroke (mm) = 88.00
- Head (Combustion Chamber Volume) (cc's per cylinder) = 34.08cc's
- Piston (Piston Dome Displacement) (cc per piston) = 1.5cc's
- Head gasket Thickness (Thickness (in) ) = In my test OEM head gasket comprimed 0.035"
- Piston-to-Deck Height (Height (in) 1mm = 0.03937 in) [negative value = out of the hole] = In my calculation is 0.002
COMPRESSION RATIO:- 11.9:1
Help with my calculations!
Thanks!
*I get
404.478 cc's per cylinder swept volume (bore x stroke)
34.08 cc's for the chamber per your numbers.
1.5 cc's for the dome volume per your dimensions.
*Assuming a 78 mm ID gasket that's .035" thick, I get
4.248 cc's for the gasket volume.
*If the piston is .002"
below deck, then that's
2.335 cc's.
*Don't forget the ring land volume. This is the area above the top piston ring, between the piston and the bore. Since I don't know the ring land height of your pistons, I will make a guesstimate of
.5 cc's (typical)
So, with these numbers the volume at TDC is
42.663 cc's. And at BDC, the total volume is
447.141 cc's. Divide the BDC volume by the TDC volume, and you get
10.4807:1 compression ratio. This is assuming your measurements are all accurate, and assuming I read your results correctly!
Now, if in fact the pistons are
above deck by .002", then the compression ratio is
442.471 cc's/ 37.993 cc's = 11.646:1 compression ratio.
HTH,
Bob
