Hi was just wondering about a couple things.I have had a couple codes come up and have changed all plugs and coil packs now it showing a power steering pressure switch and misfire on num 3 can the p/s switch cause a misfire thanks for reading.
NF Mod/Nissan Master Tech
No, the power steering pressure switch cannot cause a misfire. It is used as part of the idle control system; it lets the ECM know when the power steering is putting a load on the engine so that it can bump up the engine idle accordingly via the idle control circuit.
Thank you very much would you have any idea why it would give the same misfire code again could it be the injectors .
Anything that can cause a misfire on # 3 will cause a DTC P0303. That can include a bad plug, coil pack, fuel injector, open/shorted circuit on either the coil or fuel injector circuits, intake leak at # 3 intake runner, mechanical issue such as low compression at # 3 cylinder (bad head gasket, burnt/bent valve, etc.). You haven't given us any information as to what year/model vehicle nor engine you have, so it's tough to assist you any further. The factory service manual has a step by step procedure for P0303 in the engine control section.
