1 - 12 of 12 Posts
when im crusin my car runs better than ever it seems, but when i get on the gas a bit and hit full regular boost it will start to miss fire a couple times. But when i floor my boost gauge will hit 15 psi and missfire like every fire. it litteraly sounds when you spit with your tounge sticking out,
ive tiied a bunch of different plugs from bosch platnum +4s to ngk coppers. ive triied gapping them. 0.9- 1.1, my waste gate is hooked up. im starting to think that something important is busted.
thanks for your time.
nismo200sx16 said:
do you have any type of boost controller hooked up? to be getting spikes that high you waste gate has to be stuck, mabe you blew off the vacuum line to the actuator.rev it up and watch the actuator to see if it moves.
I chechked last night and yes it moves freely it doesnt seem to be sticking??????
Marblecake said:
Did the vac line come off the wastegate?????
Well i started to swap in a gt28 from an s14 silvia, once i took off the piping and some other things in the way i noticed that i need a flange so the stock pipeing will bolt on to the t28. So i put it back together, i have checked all my lines and connections there all good and secure. the vac line is connected to the wastegate
1 - 12 of 12 Posts
