And also, conversely, noise that the knock sensor recognizes as knock that is really harmless engine noise. Subaru's have huge problems with overzealous knock sensors.♣Zen31ZR♣ said:We've already shown that 100 octane will help it.....
You'd lose power in a car running 87 octane that should be running 91 octane, knock sensor or no. Why? Because the knock is incomplete combustion..... The typical engine only uses 33% of the energy contained in a given amount of fuel. When improper octane levels cause knock, that means far less is used.
Knock is improper flamefront propegation in the combustion chamber. Typical knock can be best explained as too fast of such propegation, instead of uniting as a single "wave" and creating the powerful push on the piston, it splits up, "echoing" off the walls of the combustion chamber and charging the middle, where one or more meet and cause a reverberation effect. All of this is supersonic and takes place in milliseconds, your brain registers it as a high frequncy tapping sound.......
Anyway, what I'm trying to say , is that you would lose power whether the knock sensor heard that noise or not. Knock sensors are designed to hear that certain frequency of where 90% of all knock occurs. However, it can happen at a much lower or higher frequency, especially if the car has any modifications that affect airflow. Air density affects knock frequency. It's possible to have knock the the sensor will not even notice, especially in older vehicles.
I see what they were saying above though. Running C107 race fuel in a 350Z will not increase power, because all that a higher octane rating does is increase an engine's knock tolerance threshold. With a stock or even slightly modified VQ35DE, this isn't a consideration, because it doesn't knock with 91. 91 octane will deter 100% of knock just as well as 107 octane will. 87 octane however, might make the engine knock, which would activate the knock sensor, which triggers the ECU to retard the timing.
