BlankgazeX said:
ok idiot, run 87 in your car, but dont tell other peole to, because you are too ignorant to realize IF THE KNOCK SENSOR FAILS A 350Z WILL BECOME SERIOUSLY FUCKED UP WITH 87 OCTANE GAS! and like i said, you lose power with lower octane BECAUSE of the sensor, is that what you are disputing? or are you disputing my statement you WILL NOT gain power from higher octane?
its a high performance car, use high performance gas... god i went through with this shit in the qr section with spec V's, some dumb ass is gonna have 100 people fuck up thier cars to save 30 cents at the pump...
in the end, if your car says 91, run 91, 87 will hurt it, 100 wont help it, use what is recomended...
We've already shown that 100 octane will help it.....
You'd lose power in a car running 87 octane that should be running 91 octane, knock sensor or no. Why? Because the knock is incomplete combustion..... The typical engine only uses 33% of the energy contained in a given amount of fuel. When improper octane levels cause knock, that means far less is used.
Knock is improper flamefront propegation in the combustion chamber. Typical knock can be best explained as
too fast of such propegation, instead of uniting as a single "wave" and creating the powerful push on the piston, it splits up, "echoing" off the walls of the combustion chamber and charging the middle, where one or more meet and cause a reverberation effect. All of this is supersonic and takes place in milliseconds, your brain registers it as a high frequncy tapping sound.......
Anyway, what I'm trying to say , is that you would lose power whether the knock sensor heard that noise or not. Knock sensors are designed to hear that certain frequency of where 90% of all knock occurs. However, it can happen at a much lower or higher frequency, especially if the car has any modifications that affect airflow. Air density affects knock frequency. It's possible to have knock the the sensor will not even notice, especially in older vehicles.
