i need to know how to remove my steering wheel and belts. Im tryin to replace the belt and i can figure out how to get the freakin belts off ,oh yeah and how does a vtc help and where is it located under the hood.
Usuallly this is what you need. Does anyone else think his question makes sense? Take off a steering wheel to remove belts? Or is this two questions? The Main belt comes off easy. Remove bolt on idler pulley or loosen and belt will become loose. Power steering/waterpump has a tensioner bolt you have to loosen (get under car to do this, think it's a 12mm)Youll need a puller to remove the steering wheel.
