so im pulling out downhill in first or what i think is first and the car starts shutter like it would when pulling out in a high gear. then i notice that the shifter is out of position. then i notice that even though its "in gear" i can freely move the shift nob left and right. so i figure the linkage broke and it stuck in a high gear. so i creep home and start pulling apart the center consult and i see two cables coming into the car the one on the right is conected to the shift lever. the cable on the left is conected something else that im not familar with and it is not conected to the shift lever, i do not know if this is normal or not. also i looked under the hood and both cable were moving there corosponding pieces that connect to the tranny. right cable on the top left cable on the bottom. so everything looks in order except for the obvious problem. im open to suggestions
