1 - 9 of 9 Posts
ALl,
I need your help in locating MAP sensor.
Check engine light is on on my 1999 Sentra GXE (1.6).
i m getting code P0105
Autozone folks told me this is for MAP sensor/ciruit problem.
I am curious to know, where is this MAP sensor located, how does it look like
it might be a minor fix. I want to look at it first before spending an arm and a leg
to dealership.
Please help.
Thanks in Advance
dee
p0105 is showing as absolute pressure sensor. look that up on google or sr20forum, you'll find instructions for checking it
Discussion Starter #4
My apologies: MAP sensor problem is on a 97 sentra GXE
clean_B14 said:
the GA16 doesn't use a MAP sensor to measure air flow. we have MAF sensors... maybe they gave you the wrong code?
Sorry for confusion,
I have a 97 sentra GXE
Does 97 GXE has a MAP sensor or MAF sensor.
Thanks in Advance.
Dee
Discussion Starter #6
correction: MAP sensor problem in 97 sentra GXe not 99 GXE
karson said:
ALl,
Check engine light is on on my 1997 Sentra GXE (1.6).
to dealership.
Please help.
Thanks in Advance
dee
Sorry for confusion, i have a 97 nissan sentra not 99 sentra.
I asked Autozone for part price, they mentioned iMAP sensor to be $400+.
IS there any place i can buy used sensors.
Please advice.
BTW: I still havenot figured out where is MAP sensor located and how does it look like.
Please help.
Best Regards
try car-part.com
nissans do in fact have a absolute pressure sensor, but they are not used for air/fuel metering.
The 96 nissan sentra with the 1.6 that my customer has for which I'm dealing with this issue has both a maf and a map sensor.
Although on the map sensor itself, which is located on the firewall mounted on this gold color bracket more towards the center with a single vacuum line and a connector, it says boost pressure.
1 - 9 of 9 Posts
