I have a 95 Nissan D21 Hardbody, V6, 3.0 4x4, 169,000 miles. I have over 10,000.00 in it since June of 2019. It is currently cutting out, no power, 40mph if I am lucky by the time I get to the top of a hill, check engine light comes on & then goes off, using gas like there is no tomorrow. Also speedometer is sporadically not working. Supposed to have my son cut out the Catalytic Converter Sunday & straight pipe it. Please any correct guidance would be so greatly appreciated.
Thank You,
Michelle
Sup Mod keeping the peace
Since the "check engine light" keeps coming on then off repeatedly, the ECU is reporting a fault. You need to get an ECU readout to see which code is being set. There's a good chance that the problem might be caused by a bad MAF or a bad camshaft position sensor that's located inside the distributor or there may be a problem with the charging system.
Software Developer
Check the codes because his ECU is in limp mode.
That's what I told him when he posted this on Facebook earlier today
NF Mod/Nissan Master Tech
I would figure out what's wrong with it before tampering with the catalytic converter; there may be nothing wrong with it. If you suspect a restricted exhaust, do an exhaust back pressure test. If you live near an Autozone or Advance Auto Parts, they may have a tester in their tool loaner program. This could also be caused by a failing fuel pump, so test the fuel pressure and make sure it's within specs.
