Hi Guys
I am installing a GPS tracker in my 2023 Rogue Platinum. It also has an engine cut-off relay. I want to install the same and isolated the IGN_ECM fuse to use which cuts off the engine when removed i.e. when the power is cut of to that fuse in the engine compartment fuse box.
The problem is the realy needs to installed in serial. I have no idea how to bypass the fuse. Fuse-tapping or piggybacking will not work as it will keep the fuse system intact. I want something which can be put in place of the fuse (in place of the original fuse but retains the original fuse functioning i.e. blowing off in case needed). I do not want to cut/splice any wires (also those are not even visible)
Can somebody guide me on how to go about it? Or is there any other fuse or route that I should take?
@VStar650CL : tagging you just in case
