CLEANING THE BATTERY AND TERMINALS.- If the top of the battery is dirty, using a stiff bristle brush, wash it down with a mixture of baking soda and water. This action will neutralize and remove the acid-dirt mixture. Be careful not to allow cleaning solution to enter the battery.
To clean the terminals, remove the cables and inspect the terminal posts to see if they are deformed or broken. Clean the terminal posts and the inside surfaces of the cable clamps with a cleaning tool before replacing them on the terminal posts.
CAUTION
Do NOT use a scraper or knife to clean battery terminals. This action removes too much metal and can ruin the terminal connection.
When reinstalling the cables, coat the terminals with petroleum or white grease. This will keep acid fumes off the connections and keep them from corroding again. Tighten the terminals just enough to secure the connection. Overtightening will strip the cable bolt threads.
