1 - 7 of 7 Posts
I'm pretty sure its behind the center stack (radio, HVAC controls). You remove one of the kickpanels (pretty sure its the driver's footwell) to get to it. Try running a search, I've posted pictures before. You should have luck if you search for "check engine light."
its behind the panel to the right of the your gas pedal, period.
hes rite its under the radio it has two bolts holding it in. and determining why your looking for it you may want to know that it has a self dionostic screw if you have error codes saved you can read them through your service engine light. if you need more info feel free to ask
ok i found it and ran the self diagnostic and it gave me a code 55 which equals no problem. my fuel pump is not recieveing power when i try to start it fires once but wont start. theres no gas getting to the engine . what should the read out be on the wires going in to the fuel pump? should we check the 2 pin or 3 pin wire?
1 - 7 of 7 Posts
