hey all.. ok so heres the problem.. just got done swapping a beat up ga16de wit 200+ miles on it wit one that has 100k... everything is connected except a couple of vaccum lines that we have no clue where they go... the car turns but does not start.. i pulled an ecu code that says manufacurer control. ignition system or misfire...there is absolutely no spark. not from plugs.. not even from distributor.. i checked the distributer.. it turns fine.. but no spark is produced... we have checked everything.. we even swapped distributers .. still no spark.......what could possibly causing this problem.....the battery is good, starter is good, alty is new. we are out of ideas... could the ecu have gone bad? ive used a code scanner from advanced auto.. that pulled the code out.. so the ecu is accessible.. and i am able to erase the code no problem.. all the fuses hvae been checked.. any ideas would be helpful thanks guys
...fellow nissan owners
