OK........got all the other wiring problems figured out......now....installed Projectors w/ Halos. NO Low Beam?? grounds are all around .6 ohms....so the grounds are good. All the wiring is good....check with an ohms meter so they are all good.......any ideas.....anyone have this same problem and figured out the cure for it??
Thanks
Banned
here is the problem... the wireing harness has 2 red wires to the battery right... those wires suck battery power.. not alternated battery power.. so your battery \ fuse gets ate up ASAP.. what happens, is when one thing is powered, the 2 red battery connectors BOTH make power, so either Both lights turn on. Or you can just go ahead, and make your own harness that goes from halo's, to headlight harness... just cut and splice a few wires. and get rid of that butt ugly wireign harness
ok???
so........with the harness supplied from matrix.......whats an easy way to re-do this??.........and those are both fused so it wont blow a batt fuse......one of them would blow way before the batt fuse in the fuseblock........
