anyone know a way to fix my heat problem.. it only works on setting 4 and thats a high setting and blows hight as well and when its off its off.. anyone help?? thanks in advanced
The blower motor has a couple of 20A fuses in the fuse box. The resistor in the airbox is bypassed on the high speed. To locate the resistor look at the passenger side towards the blower motor and is in the air stream.
Forget about the fuses, go straight to the blower motor resistor in the airbox. You can see it if you look upwards from the passengers foot well. it has an electrical connector connected to it with 4 wites going to it. It's held in by 2 screws.
Remove it and check it for continuity between the electrical connectors with a multimeter. if any of the connections appear as an open circuit (i'm at least one of them will be), buy a new one and replace it.
Dan.
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
