would an sr16ves head fit on a ga16des bottom end?
also , what car does the sr16ve come from? i found something about it on a japanese website but all i found was something that i think is chassis codes::
HB12/JB14/EN15/HN15/HNN15/JN15
the sr16ve head does fit the sr20de block. The only major problem is triggering your vvl. Some people have used jwt ecu reprogramed for the vvl some also use 2 msd rpm switch for each cam.
Pros on the rpm switchs is there constant adjustability while the jwt is set once and needs to be reprogramed each time you wanna change it.
Also the blocks from the ve and de are a little diffrent but for the most part the same. One major diffrence is the ve has oil squirter ports in the block.
Thats just the few things to take in consideration i am sure other can give you more information than i can.
CORY
