Hey i recently bought a 96 nissan 200 sx and had it for about a month. A week ago the passenger headlight went out so i bought a new bulb replaced it and found out that the bulb was good. I then checked the fuses and all them are also good. The driver headlight/ high beam works but the passenger wont. The DRL both work but sometimes dont come on when i start the car but if i slam the door they will come on sometimes. Is this a ground issue? if so where can i find the grounds on the car. I found 2 near the headlights which i cleaned. and i cleaned the main ground coming off the battery on the body.
get back to me if you think it is a ground for sure and where i can find any other grounds that might be corroded
very much appreciate it
Discussion Starter #4
yeah i did what the tutorial said and cleaned the contacts along with the sliders which were dirty. I put it back together and tried it and the right headlight still dont work along with the driving lights. Any other possibilities? or do you think the switch its self is just bad?
