Hi, Recently I wrote about the problem of my header. I installed a custom made header to my 1994 sentra, but aparently the O2 sensor was wrongfully installed, because my CHECK ENGINE light is always ON. My question is if it can be corrected, of if I let that the way it is now, it can damege my car?????
Pull the codes from the ECU, so that you can be sure it is in fact the o2 sensor.
in^3,N20,RPM,PSI
well the combustion chamer temperatures will be higher with a malfunctioning egr... make sure you have no leaks in a vacum line for the egr system
