1 - 7 of 7 Posts
Hello,
I'm replacing the head gasket on a 2001 sentra 1.8
Does the entire intake have to come out? I've got it stripped down , exhaust off... feul rails out of the way, cams out... head bolts out.. it looks ready to come out but I'm not sure if I have to take out the intake or what because it doesnt seem to be coming loose
Help!
2018 Nissan Pathfinder SL
I have not worked on a QG, but did you check for a brace under the intake, the GA and SR has one.
Most lift out with the intake.....
Did you download the FSM ?
If you are sure its ready to come out, dont force anything yet....
Spin the engine over with the starter, you said the cams are out, ( pull the fuel pump fuse if you haven't already.)
The compression pressure will help you break the head free.
head gasket
Thanks for the reply. I did find a service manual online.. there is a section on "head removal" which mentions nothing about the actual disconnect of the intake... it only states "remove head with intake"
So I'm not sure if that means the intake comes with it....
If you know of anywhere I can search It'd be much appreciated. Perhaps this has the "brace" you refer to... where exactly was it?
well it says to "Remove intake manifold rear supports." see number 8.
So these were under the intake manifold and i removed form under the car when working on the SR starter.
Will try and find a drawing or picture.
Removal
NIEM0057
1. Drain engine coolant from radiator and cylinder block.
Be careful not to spill coolant on drive belts.
2. Release fuel pressure.
Refer to EC-67 [QG18DE (except Calif. CA Model)], or EC-743
[QG18DE (Calif. CA Model)], “Fuel Pressure Release”.
3. Remove air duct to intake manifold collector.
4. Remove engine drive belts.
5. Remove front splash undercovers.
6. Remove front exhaust tube.
7. Before removing intake manifold collector from engine, the
following parts should be disconnected to remove intake manifold
collector:
 EGR tube
 Fuel injector connectors
 Ground harness
 Breather pipe
Harness connectors for:
 IACV-AAC valve
 Throttle position sensor
 Throttle position switch
 EGR temperature sensor
 Water hoses from collector
 Heater hoses
 PCV hose
Vacuum hoses for:
 EVAP canister
 Power brake booster
 Fuel pressure regulator
8. Remove intake manifold rear supports.
9. Remove exhaust manifold.
SEM870F
10. Remove ignition coils.
11. Remove spark plugs.
sweet
Awesome thanks so much... We were working at it yesterday and I said "I checked with someone online and they mentioned braces in the back... " BAM we found 'em and it worked! I just dropped the head off to be inspected!
Thanks again :)
Let us know how it turns out, anything you learn, there are to many of there on the QG
1 - 7 of 7 Posts
