Was driving and it started to get hard to put into gear. came to a stop and tried to put it into first and it grinded like I didnt have the clutch pushed in but I did.
So I checked the master cylinder reservoir and noticed it was empty... put fluid in and bled the system. Still had problems so I pulled aside the boot on the slave cylinder and noticed fluid in it so I've replaced the slave cylinder and it seems to have helped somewhat...
My dilema is that when I start the truck, If I push the clutch all the way in its hard to go into first gear... I have to let off it a little and then it slips in. also noticed that if Im at a stop and I push the clutch all the way in it seems to creep forward as if in letting off the clutch... but if I release it a little it stops. I cant figure it out. I've looked at the master cylinder and its not leaking so did I not bleed it properly or something??? any info or suggestions would be greatly appreciated!!!
