1 - 11 of 11 Posts
USACI here I come
I have looked in to it. If I remember correctly we don't have the proper type of lock mechanism to use one of those soleniods. What I am planing on doing is using linear actuators mounted behind the seats and attaches to the trunk arms.
ive done it to mine, its not hard at all. right now ive got it so that you can only open my trunk with the remote or by a button hidden by the licensce plate( but only if the key is in the ignition in the on pos ) the solinoids will work, if you wire them right. it also depends on what alarm you have or if you have one at all. DEI sells a powered trunk release kit as an add on or stand alone option. if you are going to use it with a current alarm/remote the system must have a pos+ aux output wire, and you MUST use a relay on this wire if its a dei alarm the aux wires are usually in the millivolts, hints the use of the relay. here is a link to the site where i got my solinoid kit . its the 522T near the bottom. as far as connecting the cable on the solinoid to the existing latch, if you are looking at the latch (with the spare tire and all of that crap out) there is the cable that runs from the cab to the latch, you just remove the cable and attach the solinoids in the same manner. pm me if you have any Q's on this
Banned
stealth... i think 99se-l has his done. i noticed in a post of his he said "one button on my remote is to pop my trunk" so you might want to PM him :thumbup:
Red line chaser
I had my old 200 wired up to pop the trunk w/ my alarm remote also. The real fun part was that the only visible part of the whole install was the two screw heads that held the solenoid in place. I plan on doing that with my current car when I do the alarm install on it. Somewhere in the near future when it's not 15 degrees out around here.
new motor & tranny
i got the DEI alarm, Viper 791XV and it has 6 aux channels. I'll have to talk to my friend, he is a DEI dealer. He told me he could install the power trunk release and hook it up to my alarm for $60
Please Shift Here
The 99 GXE has a trunk popper stock???
I've messed with mine a bit. I have a viper alarm and chan. 2 is set to activate the solenoid. Unfortunately, I still haven't come up with a way to mount that darn thing. I was going to add it onto the existing cable, but I just came up with the idea to just replace the entire cable with the electronic popper thus disabling the lever inside the car.
I'm thinking this could have a double advantage b/c it would prevent theives from opening my trunk. You would either need a key or the remote to open it and since my battery is in the trunk, it's that much harder to disable the alarm
I can take pics of mine maybe help u see mount
Maybe I could post a few pics do u need to be a premium member and if so how much is that
Randy :cheers:
1 - 11 of 11 Posts
