Is it possible to tighten the harmonic balancer without the ring gear stopper?
I recently put in a timing kit into a Nissan Pathfinder 02 and tried (RGS) and I was unable to keep the cams or crankshaft from moving. It however did start up but was clearly not timed rite so going for my 2nd and last attempt.
What if you place a belt in-between the tensioner and harmonic bal. It would bind itself tight enough the torque it down. What are your thoughts.
