As stated in the CEL thread, have you had the recalls done to your car? The crank position sensor has a recall on it and the symptoms of the problem sound the same.
2002 Nissan Altima S NHTSA Recall ID Number: 02I001000
Recall Date: APR 17, 2002
Component: AIR BAGS
Potential Units Affected: 116500
Summary: THIS IS NOT A SAFETY RECALL IN ACCORDANCE WITH THE SAFETY ACT. HOWEVER, IT IS DEEMED A SAFETY IMPROVEMENT CAMPAIGN BY THE AGENCY. ON CERTAIN 2002 NISSAN ALTIMA MODEL VEHICLES MANUFACTURED PRIOR TO MARCH 16, 2002, ONE OF THE SENSORS FOR THE AIR BAG SYSTEM DOES NOT WORK AS WELL AS EXPECTED IN HIGH-SPEED OFF-SET CRASH SITUATIONS.
Consequence: THE AIR BAG SYSTEM DOES NOT WORK AS EXPECTED.
Remedy: DEALERS WILL REPLACE THE AIR BAG SENSOR. OWNER NOTIFICATION BEGAN APRIL 15, 2002. OWNERS SHOULD CONTACT NISSAN AT 1-800-647-7261, CONCERNING THE PROBLEM.
Notes: NISSAN NORTH AMERICA, INC., P2110
2002 Nissan Altima S NHTSA Recall ID Number: 03V061000
Recall Date: FEB 27, 2003
Component: AIR BAGS:FRONTAL
RIVER SIDE INFLATOR MODULE
Potential Units Affected: 64562
Summary: ON CERTAIN VEHICLES, THE ELECTRICAL CONNECTOR FOR THE DRIVER AIR BAG MAY COME LOOSE. IF THE CONNECTOR COMES LOOSE, THE SUPPLEMENTAL AIR BAG WARNING LIGHT FLASHES INTERMITTENTLY.
Consequence: THE DRIVER SIDE AIR BAG WILL NOT DEPLOY IN THE EVENT OF A CRASH, INCREASING THE RISK OF PERSONAL INJURY.
Remedy: DEALERS WILL INSTALL A RETAINING CLIP ON THE CLOCK SPRING ELECTRICAL CONNECTOR. OWNER NOTIFICATION BEGAN APRIL 21, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT NISSAN AT 1-800-647-7261.
Notes: NISSAN NORTH AMERICA, INC., R3001
2002 Nissan Altima S NHTSA Recall ID Number: 03V251000
Recall Date: JUL 14, 2003
Component: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
Potential Units Affected: 377000
Summary: ON CERTAIN PASSENGER VEHICLES SOLD OR REGISTERED IN THE STATES OF ALASKA, COLORADO, CONNECTICUT, IOWA, IDAHO, ILLINOIS, INDIANA, KANSAS, MASSACHUSETTS, MAINE, MICHIGAN, MINNESOTA, MISSOURI, MONTANA, NORTH DAKOTA, NEBRASKA, NEW HAMPSHIRE, NEW YORK, OHIO, PENNSYLVANIA, RHODE ISLAND, SOUTH DAKOTA, UTAH, VERMONT, WISCONSIN, AND WYOMING. AT EXTREMELY COLD TEMPERATURES, MOISTURE IN THE FUEL TANK COULD FREEZE AND FORM ICE CRYSTALS. THESE ICE CRYSTALS MAY OBSTRUCT THE SUCTION OPENING OF THE FUEL PUMP.
Consequence: THIS CAN PREVENT THE SUPPLY OF FUEL TO THE ENGINE AND CAUSE THE ENGINE TO STOP, WHICH COULD RESULT IN A CRASH WITHOUT WARNING.
Remedy: DEALERS WILL INSTALL A SCREEN AT THE SUCTION OPENING OF THE FUEL PUMP TO PREVENT ICE CRYSTALS FROM BLOCKING THE OPENING. OWNER NOTIFICATION BEGAN ON AUGUST 18, 2003. OWNERS SHOULD CONTACT NISSAN AT 1-800-333-0829.
Notes: NISSAN NORTH AMERICA, INC., R3012/P3142
2002 Nissan Altima S NHTSA Recall ID Number: 03V084000
Recall Date: MAR 11, 2003
Component: ELECTRICAL SYSTEM
Potential Units Affected: 338000
Summary: ON CERTAIN VEHICLES EQUIPPED WITH THE 2.5 LITER ENGINE, THE EXHAUST PIPE HANGER PIN MAY CATCH DEBRIS FROM THE ROAD THAT COULD BE IGNITED BY CONTACT WITH THE MAIN CATALYST.
Consequence: THIS CONDITION COULD RESULT IN A FIRE.
Remedy: DEALERS WILL REMOVE THE PROTRUDING PORTION OF THE EXHAUST PIPE HANGER PIN. IN ADDITION TO THE CORRECTIVE ACTION, IN ORDER TO REDUCE THE RISK OF FIRE IN THE EVENT OF POOR OR IMPROPER MAINTENANCE THAT COULD RESULT IN OIL SPILLAGE, HEAT SHIELD(S) WILL BE INSTALLED ON THE PRE-CATALYST AND EXHAUST TUBE. OWNER NOTIFICATION BEGAN ON JULY 28, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT NISSAN AT 1-800-647-7261.
Notes: NISSAN NORTH AMERICA, INC., R3007/14/15/16/17
2002 Nissan Altima S NHTSA Recall ID Number: 03V455000
Recall Date: NOV 17, 2003
Component: ENGINE AND ENGINE COOLING
Potential Units Affected: 630000
Summary: ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS.
Consequence: THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH.
Remedy: DEALERS WILL REPLACE THE CRANK POSITION SENSORS. VEHICLES INVOLVED IN A PREVIOUS RECALL CAMPAIGN, 01V357, ARE ALSO INCLUDED IN THIS NEW CAMPAIGN. THE REPLACEMENT SENSORS USED IN THAT CAMPAIGN ARE ALSO AFFECTED. OWNER NOTIFICATION BEGAN ON DECEMBER 22, 2003. OWNERS SHOULD CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200.
Notes: NISSAN NORTH AMERICA, INC., R3021/R3022
