The guage lights in my b14 have completeley shut off. the guage itself still works just the backlight wont come on. the lights around it like the seat belt and gas light come on but not the guage lights. I checked all the fuses under the dash and under the hood. is the bulb blown??? idk. is it easy to change the bulbs in the cluster???
Cone Dodger
if you remove the instrument cluster (gauges), you should be able to see some light bulbs that illuminate the back lighting of the cluster. these are usually 194 type bulbs or you can switch to LED replacements for a different color with less heat.
i don't usually disconnect anything, since i can pretty much access the bulb sockets to prevent the likelihood of setting off any warning lights.
