1 - 7 of 7 Posts
2018 Nissan Pathfinder SL
you must re-wire the 3 plugs.
It is NOT a simple unplug the old one Plug in the new one.
DNE's VZR Conversion
i had it done and it wasnt easy as plug and unplug there are some wiring to be done and also you will need a wire tapped into your ECU into the tach side or it wont be active.
well i have the 200sx guages and someone told me that i coudnt use it . is that true?
no that isnt true.
depends on if your the donar cluster is a 200sx SE from 95-99 or a 200sx SE-r from 95-99 it will work you will have to do some wiring to get it to all match up
for the se-r you must have the 2.0 l motor for your tach and speedo to read correctly.
Re: Ga vs SE-R clusters.
I understood they are interchangeable, only the red line on the tach is wrong.
tires are same diameter so why would speedo be wrong ?
1 - 7 of 7 Posts
