I found the govenor gear! this b-12 has a/t trans. and was hanging,rough shifts from 1st-2nd! changed fluid and filter! later found out that the governor gear was a common problem in this model and to pop cap off and if it turned than it was bad! had a hard time because everyone said it lifted right out but under the lip there was a 10mm bolt holding it in! when i pulled out govenor and shaft was intact but no gear or teeth went by nissan and they said they didnt know if the teeth was made on the shaft or an additional item seperate! does anyone here with there great minds know anything about this and maybe a pic or part#
thanks,
