Hi guys,
My 2001 Nissan Caravan (Homy) E24 is not getting any voltage to the glow plugs. The light on the dash is also not coming on at all.
I have checked the plugs, and they are showing 0.7ohm resistance.
I have checked the bulb on the dash and it is working.
The relay is getting 12v from the battery, however it is not giving any voltage to the plugs.
The relay clicks on and off like it should.
I have tried a second hand relay, and the problem was still there. (perhaps the second hand one is no good too?)
The relay outputs voltage only once the engine is actually running (not when the key is in start position, which is when I need voltage to pre heat the plugs)
Thanks for any advice that anyone may have!
