1 - 13 of 13 Posts
Hey guys. Did a trans swap on my 95 2wd 5 speed a few weekends ago with a rebuilt unit, and the only complaints I have is that its a little tough to get into 1st gear from a dead stop. If I'm rolling it does OK, but if I'm dead stopped I usually have drop it into 2nd, then slam it into 1st. It doesn't grind or anything...just "sticky". I used the cheap 75/90 gear oil from autozone ...I think its called "coastal"...couple bucks a quart. I adjusted the clutch, and that hasn't seemed to help any. I'm thinking of draining the oil and trying some of the synthetic stuff like this:
eBay Motors: Royal Purple Synthetic Max-Gear Oil 3 BOTTLE 75-90 (item 370060508558 end time Jun-20-08 13:26:42 PDT)
You guys think this is worth the money? Any opinions on wether it will really make a difference?
Moderator
FYI, you need a GL-4 rated gear oil. Synthetic oil works wonderfully and reduces drivetrain drag, some people report better mileage with synthetic gear lube.
..talked to my transmission guy, and he says run regular 30 weight motor oil in the trans. Says 75/90 is to heavy. Will give it a try and report back...
...put regular old castrol 10/30 in it yesterday, and can tell an immediate difference. Much smoother, and doesn't stick going into 1st. Wonder if there can be any adverse affects long term? Think I'll change it after 6 months or so just to see how the oil looks. If no significant break down, I'll stick with it.
Moderator
Well hey, that's different. Cheaper, too!
...OK, OK, I'll retract my earlier statement. Trans is back to being sticky...and maybe a little worse than with heavier old. Not sure if the 30w breaking down or what, but I'm gonna change it back to 75/80w this weekend...
...yes, I went back to 75/90 and it shifts great now with no problems. I did refill it with Valvoline brand gear oil. The 75/90 stuff I put in the 1st time was "Coastal" brand??? Its autozones El Cheapo brand. The Valvoline was only slightly more expensive (less than a dollar)....but like I said it shifts like it should now. Only have problems finding reverse on occasion...but no problems with any other gears.
Just tought I would revive an old thread for posterity. ;)
I'v been using Redlines MT90 for the last few years now, and my truck shifts like a dream. I always had issues in cold weather, but I don't have this with MT90.
You DO NOT want to use a GL-5 rated gear oil like Valvoline in these transmissions. The fluid must be rated GL-4.
GL-5 fluids contain sulfur-based additives that attack yellow metals, and these transmissions contain bronze synchros.
Your only real options are Red Line MT-90 and Amsoil MTG, unless you want to go exotic and order something like Motul Gear 300. Pennzoil makes a conventional GL-4 gear oil, but it can only be purchased from distributors, and the minimum purchase is 5 gallons.
I will say this. I purchased an old 86 D21 and the guy stated the transmission had been rebuilt a couple years back, he even gave me the receipt. Anyway, I got everything ready to change all the fluids and when I crawled under the truck there was a tag wired to the transmission that read "fill with 5w30 motor oil". Thats what I did, no problems. I think it is something to do with the newer parts. Many manual transmissions use ATF.
1 - 13 of 13 Posts
