Ok so I have a 91 (not sure model) pick up with the 2.4L and I won't start, Just turns and turns. When you give it a little gas while cranking you get a small pop (which sounds like it comes from the intake). I did all the basics, Check spark, Got gas, Timing is good.. I check the ohms on the TPS and there with in specs along with I check to see that the map is getting Voltage and it is.
Any Ideas guys? Any thing I might have missed.
