I Have heard that this DOHC engine is a bulit Prof engine........Is it a good idea to make mods to a ga16 with 200k on the engine and car?Ya kno im a younger guy 20....and still like to hell raise every now and thn way more than i should im jw if it will hold up under a fully bolt on set up with cams and ecu?
who needs clearcoat
Small things like an intake, exhaust, pulleys, and slightly advanced timing shouldn't be a problem, but if you're going turbo or really plan on raising lots of hell I would definitely look into a rebuild or a lower mileage motor. Then again I turbocharged mine with 150,000 but I also baby it alot.
