I am writing this as a post for newer members who are interested in increasing the power of their GA16DE engines. Seeing the results of other such posts, I do humbly request that other members don't just post "go SR20". That doesn't help anybody out, and discourages a lot of people from trying to do anything with a perfectly good powerplant.
So, you have a Sentra / 200SX and you want it to have a little more "kick" than stock? Well, other than an engine swap, there are a variety of different approaches you can go. Here are just a few (with prices that I could find).
1. cold-air intake kit
This is a basic everyday change. This kit shortens the factory intake piping, and removes the factory airbox. (These are retail prices, eBay costs much LESS)
Injen IS Series Short-Ram = $181.95 ('95-'98)
K&N FIPK Air Intake = $191.84 ('91-'98)
2. exhaust headers
A series of exhaust pipes even spaced and distanced from the cylinder head to provide better flow, response, and power.
Pacesetter Headers (black) = $137.07 ('88-'98)
OBX Performance Headers = $174.85 ('88-'98)
3. underdrive pulley
Lighter weight crank pulley that provides better response.
*I know Unorthodox Racing made a crank pulley for the GA16DE, but their website does not list one available*
4. ignition system
Upgrade your ignition coil, spark plug wires, and spark plugs. I recommend either MSD or NGK components.
5. port matching
Make sure you ports match the manifolds. Fairly easy to do using a Dremel or other tools. If you are inexperienced in this, have a machine shop do this for you. The GA16DE has very small ports, and this is one of the engine's major drawbacks.
6. emissions removal
THIS IS ONLY FOR REGIONS WITHOUT SMOG TESTS! Remove your EGR system from the GA16DE. This includes carbon canister and other miscellaneous junk associated with it. If you have car emissions, do not do this.
This is just a beginning list. All of these available parts can usually be found on eBay at reduced prices that make them even more affordable.
2. exhaust headers
4. ignition system
5. port matching
