1 - 20 of 20 Posts
Hello, I would like to know what would be the highest rpm that a GA16 engine would stand without breaking apart of course.
Cause I drive mine (sometimes) to 8000 - 8400 rpm, and the connecting rods failed 3 times :loser:
Thx
Do you have a modified ecu? The stock ecu has a rev limiter of 6900 rpm. When you buy a JWT ECU, they raise the rev limit to 7300 rpms. But if you are reving that high and breaking the connecting rods, then, well, you should be able to figure that one out. It also depends on what engine mods you have. But, do a forum search cause I know this has been discussed before.
- Aaron
- Aaron
Mine is a carburated (GA16DS) b13, so no ECU to limit the rpms :thumbdwn: .... the engine has some mods, for example: lightweight flywheel, crankshaft, pulleys, performance cams, twin 40mm webers, among others.
I'll take a look but I would appreciate your help.
Thx
Wise Cracker
JWT raises the rev-limiter on the GA16DE to 7300 rpm's. If you can confirm that the two motors have the same connecting rods then I'd say 7300 is safe. Aside from the connecting rods valve train harmonics play a huge role in how high an engine can rev and at that range (8000) RPM's you will want to look in to different valve springs designed to work with your cams.
And I gotta ask, why have you let it rev that high on more than one occasion?
Thx for your comments Wes, they are really appreciated. I’m pretty sure that the GA16DE and the GA16DS have the same connecting rods so maybe that would be the safe limit. The thing is that I’m using stock valves and valve springs and they seem to work well for those revs. I haven’t had any valve problems yet.
Why have I let it rev that high on more than one occasion? Cause even at 8000 rpms (sometimes a little bit more), on 1st, 2nd and 3rd gear at the ¼ mile the car seems to respond well.
And I’m starting to suspect that those revs are not healthy for my engine :rolleyes:, so I would like to know the reason why only 7300 rpms are safe, why not more??, can I use forged internals??…. or based or your experience what would you recommend?
Wise Cracker
Apparently you have a steep learning curve. Broken rods on 3 occasions shold more than tell you it is not safe! And hae you dynoed your car to see what kind of power you are making up there. I would imagine that the power is falling off up there so there is little to no dvantage to raising the red-line. As stated the stroke needs to match the intended RPM range. In this case the motor is better suited to turbocharging.
Did you put a Honda engine in their or something? The GA16 does have a little torque. USE IT. Get a turbo kit if you want to maximize its potential. If you want super high revs go get a Spoon or a Wankel. :thumbdwn:
Wise Cracker
How many times do we have to say the same thing? Turbo has already been mentioned twice. In the tech section we TRY to keep it BS free so recommending kitchen utensils and saying the same thing others said isn't necessary...
Discussion Starter · #14 ·
hahahahaha...... I would love to install a turbo but the problem is that it´s a carburated motor remember????, and if you know how to do it, please advice cause if it's possible (reliable) I'll be glad to do it.
Regards.
8400 RPM, no wonder stuff broke. The pins on those rods should snap according to bob legere who had his modified to fit a bigger pin. I'm not sure if teh b14 ga16de has better pins, but who knows. For the time being, best you can do is get nismo cg13de valve springs and custom adjustable cam gears. This will give you the ability to lower the cylinder pressures at various piston positions during the high RPMS, lessing the load on the piston and hence the rods. Rev it to 7600 with 7800 being your adrenaline limit and you might be fine. Get a msd ignition with revlimiter so you don't over rev. There are some ga's with 40's where I live, and they are insanely fast, but like you they often fly a rod over revving. I'm still jealous though.
Super Moderator
If i remember correctly i revved my old b13 ga16de w/195k miles up to only about 6500. It was a worn out motor. I bought it with 193k thousand and it had the STOCK air filter from 91 in it :EEK:
1 - 20 of 20 Posts
