Could someone halp me remove the speed cut from my vehicle, its very annoying. what wire do i have to cut in the ecu to do so. Or what do i have to do to bypass it. I thinking Bout using a FPR some advice would be nice..
A JWT ECU optimizes the timing, VTC and removes the speed cut and raises the rev limit. its expensive, around $500 exchange.
There is a wire you can cut, i forget now which one, search and you will find. your risk !!
i looking 4 the wire to cut, cause i had it cut before an car went in d garage an come back with it so it suppose 2 be somewhere around.. wat about megasquirt ecu?
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
