hi. i have a Nissan sunny B13 1992 model. i had a CD17 engine A/T(Diesel) in it when i purchased it. Used for some time and then engine began playing up with late starts. after some time engine wouldn't start. mechanics said compression gone and fuel pump servicing required. got a GA15 engine cheap so switched from CD17 A/T to GA15 A/T....note CD17 wasn't the original engine...was probably changed by previous owner...badge reads GA13 or 14 i am not really sure...
OK i have a problem with the current setup. GA15 engine is equipped with carburator so i guess its not EFI. now while driving when car takes off, it takes a while for it to change to the secound gear and car gerks when it does. never feel anything on the other gears.v remember i have automatic transmission. also while driving when i brake at time engine kills itself..i have to start the engine while driving. This also happens when i turn either side.
Got it checked by mechanic...said carburator problem...so bought another one...changed carburator...mechanic works for Nissan dealer in my country...
same problem exists, however addition to that..now the car wouldnt move properly...even if i push the accelerator all the way to the floor..and when it does it would go up to secound gear and wouldnt go above 80 km/hr...
took it back to the mechanic, says new carb has blockages...changed to previous carb and asked for new carb to be serviced. however, now when i put in to reverse or to drive, when car switches from neutral to either forward or revers...there is a large noise from the gearbox and the car jerks badly. the engine twists slightly. i haven't drove the car since fearing that there might be damages to the gear box or the engine itself..
i have the FSM already in soft copy and i have electrical and electronic knowledge. i would really appreciate if anyone can help me in this matter.
i have spent to the end of my small pocket on this car and i am really low on finance...looking back i could have easily fixed up my CD17 engine.
i love nissan cars and i really wish to get my baby up and running.
greatly appreciate any help.
thanks
Sorry for a long post!
thanks
