I've got an '89 Sentra 2door i got from my neighbor for $50....it needed a head gasket, i had the head checked, everythings flat/good. i did the fix, and it fires right up, but when you push on the gas, it revs up to about 1200, then acts like a rev limiter has kicked in and it just goes vroom vroom vroom, up to 1200ish (i'm guessing on RPM) and back down, very quick vroom vroom noises ;-)
any suggestions? When i removed he distributor cap (during repairs) i tore one of the little rubber inserts, does the base of the dist. need to be sealed, to create a vacuum of sorts for timing advance? i've thrown the timing light on it, and it's spot on. any help?
thanks from a noob to the nissan world!
