I have had a major engine failure in a 95 g20. I want to get a replacement motor from SOKO. I talked to someone from SOKO yesterday and the only thing we are not sure of is whether a lowport intake valve will swap to a highport version of the JDM SR20DE. Has anyone done this? There is a $300 difference between the high port and low port SR20DE's. Since they are JDM I will be replacing down to the long block in any case so the question to you folks is whether the Long blocks for the 91-93 SR20DE is the same as the 94-9x SR20DE.
Thanks
Thanks
