1 - 8 of 8 Posts
i was just wondering if an ecu off of a g20 would work for my sr20. im convertingn my 1.6 over to teh beast adn i need an ecu. And would anyone happen to know if i would just need the engine half of teh wiring harness? or teh whole thing?
2018 Nissan Pathfinder SL
lots of discussion about this to raise rpm limit and remove speed limiter, any OBDII will do but if you want the good ones get 94 - 96 only. make sure auto or MT matches.
Also my ecu is stock but ive been told by a fren who knows my car that i cant boost anything above 10psi becuz the ecu is programmed to stop at 10psi n if i go over the engine will blow up..... What do u think guys? wat abt an mbc coz am still using the actuator wastegate that holds 7 psi as am also told that can be pushed up with the mbc
1 - 8 of 8 Posts
