who needs clearcoat
Can I take brakes from a 1992 g20 and put them on my 200sx 1.6L. It would be for a drum to disc conversion. If possible would I need the entire back axle, or just the spindle, caliper, rotor? Thanks for any help.
2018 Nissan Pathfinder SL
To change rear brakes on a B14 to SE-R Rear discs you have to either change the beam or get Fast brake adapters.
Then you need calipers, rotors, brake lines and E-Brake cables.
SO the lowest price might be the whole beam with all these components. make sure they dont cut the cables and brake lines.
If you go the fast brake adapter route you buy the kit and get the brake lines and adapters.
Add your calipers, rotor and E-brakes cables.
The B14 rear is different to pre 95 B13's so i don't know the answer to your G20 question, but i suspect it will not be a straight swap given the above, even if the G20 is the same as a B14 which I doubt given its year.
