ok so my friends blew his head gasket and we were rebuilding his motor but when we took the head off the valve spring covers came off and there was to washers sitting with them and we cant figure out if those two washers went in between the valve spring retainers and the covers for them any help will be amazing thanks for your help
2018 Nissan Pathfinder SL
are you talking about the valve lash adjust shims ?
You will have to re-shim all the valve to cam clearances !!
download the Factory service manual (FSM) for free at phatg20.net
Yes, these are the flat pieces on top of the bucket. they are the shims and now you will need a feeler guage when you put them back on. they should have a # on the bottom. if they are the same, no issue, insert them back in. use the feeler guage and see which one goes where by reading the feeler guage and match to the right cam lobe.
Chris 92 classic
