my 97 paty needs a new fuel tank, it leaks from everywhere...:mad:
there is no aftermarket known company that makes them, so either i have to have it rebuilded or a new from the dealer....
any other alternatives ??
thanks !
thanks !
wreckers... once out take a flashlight and see what the inside is like. If all good or decent, take it to a radiator shop and ask them to clean it out.
You can get it here.
thanks, but thats $x2 here...so ive been quoted for 750$ at my local dealer (i am not in usa but in canada so buying from courtesy part is not a good idea).
anyway, i didnt find any used localy so i had mine rebuilded at a local shop. they soak it into a heavy epoxy. lifetime garanteed, for 350$.
I had to replace the straps and they are 100$ each at local dealer :mad:
so i made some with stainles steel at my friend machine shop for free.
i replaced all the tube and hoses.
now i need to fix the evap system, all the metalic tubes are flaking down, and the solenoid right over the brake prop valve at the rear is broken (150$ at local dealer wheu euu !!!) , no wonder why there is always that CEL on !!
i think i will fool the presure sensor so the ecu will see always presure in it.
cant afford any more penys on that.
