hey i have some dsm buddys and they have told me instead of getting a diffrent fuel pump i could run a bigger wire back to it with a relay inline and i could make it push more. this this true?
No. You do not need a larger fuel pump anyway! The pump only provides pressure and your stock pump can support over 220 wheel horsepower.hey i have some dsm buddys and they have told me instead of getting a diffrent fuel pump i could run a bigger wire back to it with a relay inline and i could make it push more. this this true?
How much power do you want to make? I ask because your stock injectors at stock fuel pressure (3 bar or 44psi)your stock injectors can only support 125 wheel horsepower. If you get an AFPR and up the pressure to 4 bar (59 psi) they will support maybe 145 whp. At 6 PSI on a T25 you will make more than that. The long and short is if you plan on making ANY kind of power you need to change injectors.ya but i didnt want to have to get me ecu retuned and bigger injectures..
